Create SSH to mysql socket?
luma
Post by luma »
Is it possible to automate this with the program RoboTask? Specifically, to create a ssh connection to mysql socket and, if the connection drops, automatically re‑establish it.
See my acutally the CMD command: The CMD command establishes an SSH tunnel that forwards your local port 5001 to the MySQL socket file /var/lib/mysql/mysql.sock on the remote server 123.123.123.123. This allows you to connect locally to port 5001 and transparently access the MySQL database on the remote host, even though it normally only accepts local socket connections.
ssh -N -L 5001:/var/lib/mysql/mysql.sock USER@123.123.123.123
thx
Re: Create SSH to mysql socket?
It seems that you need to enter your password interactively.
You can automate this process using Console Application actions: actions
If you don't need to use interactive actions you can use Run Program/Open Document or Run Console Application actions.
These actions only run the specified command line.
luma
Post by luma »
thx a lot :)
luma
Post by luma »
I figured it out. post can be removed.
