Variable substitution in Check For Window
TimSpeek
Post by TimSpeek »
Downloaded Robotask today from the free giveaway and tried it out immediately. Got stumped on waiting for the window I wanted to process and found via the forum the "Test Notepad for at least 10 seconds" sample. And being me tried to make it generic. The original  task works fine, but substituting the value Noyepad for a variable does not. What am I doing wrong?
Complete task appended. Looking forward to someone pointing out my mistakes
Tim
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|0
ExternalName=STRING|"Task456"
ID=INTEGER|1476834722
Name=STRING|"Test Generic for at least 10 seconds"
ToLog=INTEGER|2
Name=STRING|"Create variable ""WINDOWTOWAITFOR"" with value ""Notepad"""
varname=STRING|"WINDOWTOWAITFOR"
varvalue=STRING|"Notepad"
Name=STRING|"Show ""END, {WINDOWTOWAITFOR} Not Found!!!"""
msg0=STRING|"END, {WINDOWTOWAITFOR} Not Found!!!"
Name=STRING|"Simple Loop"
begin=STRING|"0"
end=STRING|"10"
variable=STRING|"COUNT"
ActionID=STRING|"A_WINDOW_CHECK"
Name=STRING|"Check for Window"
abortif=STRING|"0"
action=STRING|"1"
checkfor=STRING|"0"
exact=STRING|"0"
variable=STRING|"NOTEPAD_FOUND"
wincaption=STRING|"{WINDOWTOWAITFOR}"
operator=STRING|"1"
value1=STRING|"{NOTEPAD_FOUND}"
value2=STRING|"1"
Name=STRING|"Delay 1000 ms"
delay=STRING|"10"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""{WINDOWTOWAITFOR} found"""
msg0=STRING|"{WINDOWTOWAITFOR} found"
Name=STRING|"Break"
Hm-m...
Maybe this is a bug, because "Check for window" action ignores variables
