Trigger logon
drawdream
Trigger logon
Post by drawdream »
is it possible to start a task when a user logs in.
I need this trigger for a special configuration on a server.
Thanks for any help!
Re: Trigger logon
Look at the On Local/Remote Session Changes trigger.
It can catch when somebody opens another session - remote or local.
If you want only start the task when RoboTask starts just enable the checkbox "Run task when RoboTask starts" on Triggers tab of task editor
