How can I remove a file by searching folders?
Stantoista
Post by Stantoista »
Hello, oleg. For example, suppose I have a file named test file.mp3 that is placed in various subfolders; which task should I use to hunt for and remove the test file.mp3 in these folders? Also utilizing sections of the file name such as: test*.mp3... thank you, pal.
Re: How can I remove a file by searching folders?
You can remove files in subfolders in the File Loop
Look at my example below
CatID=INTEGER|45174721
ExternalName=STRING|"Task1470"
ID=INTEGER|1627463825
Name=STRING|"delete file in subfolders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""SearchFile"" with value ""D:\incoming\test\test.txt"""
_rt_variables_produced=STRING|"SearchFile"
varname=STRING|"SearchFile"
varvalue=STRING|"D:\incoming\test\test.txt"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"filename"
date1=STRING|"20250111"
date2=STRING|"20250111"
destvar=STRING|"filename"
DuringMinutes=STRING|"1"
file0=STRING|"{SearchFile}"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"removing file ""{filename}"""
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{filename}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
You can also use a file mask with no problem
