Temp pop up message window
jonjon
Post by jonjon »
I try to make a task where the task start with ping a host. if the host is unreachable i would like RT to pop up an message about this for lets say 2 minutes. then i want it to take it away and continue the task. but i cant make it work since the user must click OK buttom before it contiues. I dont know how to make RT continue the task even if massage window is up.
BR
Johan
Some users uses the "Question dialog" for this purpose.
"Show message" action uses the system function for displaying the message and requires pressing the OK button.
jonjon
Post by jonjon »
is it possible to have that pop up without buttom. I only want the users to get a message but i dont want them to choose yes or no or cancel. otherwise it seem to work good...
cheers mate.
jonjon
Post by jonjon »
Is this topic closed ?
Question dialog contains autochoice with specified timeout. You do not need to push any buttons in this case.
