Compare 2 TEXT FILES
ganapkg
Post by ganapkg »
HI there.....
I have been using robotask for about a month already and i got a question to ask.
I have two folders which contains all contains .csv files that are FOLDER A and FOLDER B.
I want to copy all the files' name (without the path) in FOLDER A to a text file say for example TEXT1.txt. The same thing goes to FOLDER B but in a different text file say for example TEXT2.txt
The next thing i want to do is compare both the text file......and copy those files which are not in FOLDER A from FOLDER B.
Is this scenario possible???
I do not prefer to use File Monitor.
Please help
THANK YOU
Why you don't want to use "Synchronize folders" action? This can easily copy newest files from folder A to folder B
Also, there is a way to copy files, which doesn't exists in folder A, from folder B without comparison of text files. Do you want an example?
ganapkg
Post by ganapkg »
I would really appreciate if you could provide me with an example as you mentioned earlier.
Thank you very much
No problem. See the following example. This task copies only files from c:\source to c:\dest, which doesn't exist in destination folder.
BTW: Maybe you will find something else useful in our task repository
