{ClipBoardContent} Not working
muzzargh
Post by muzzargh »
If I get Robotask to highlight some text and copy it then open Notepad and paste the copied text appears as expected, however if I create a text file and use {ClipBoardContent} in the text body, nothing appears?   Any ideas?
Murray
mikronos
Post by mikronos »
Hi,It seem to work fine on my computer Do you use the last version of robotask ? and ( better ) can you send us your script file ? (just the part that doesn't work )-Mikronos
This is a small bug, which already was fixed in the new release. If clipboard contains not only text (e.g. HTML or RTF in addition to text) the {ClipBoardContent} variable sometimes returns an empty value.
muzzargh
Post by muzzargh »
I was using ver 2.4 but now that I have 2.5 installed everything is OK.
Cheers for the support.
