Notify me whenever a file in a directory has a changed name?
populargown
Post by populargown »
If I create or modify a file within a folder, is there a command that displays the file name and a prompt indicating the modification? I trust that you comprehend my inquiry. Thank you kindly.
Re: Notify me whenever a file in a directory has a changed name?
Look at File monitor trigger. It can save separate file lists and pass them to the task
