I use an INI file with section settings and about 20 values
To read all those values in the variables I use INI read twenty times and it works.
I cannot figure out how to use the INI loop to do the same thing.
Is it possible?
Christian
INI files and reading them
photoevents
- Contact:
Re: INI files and reading them
Look at my examples below.
This example reads INI section in the loop into variable using JSON format
This example reads INI section into separate variables.
But note that KeyName may contain an unacceptable value for the variable name. The INI file allows almost any value for the key name.
In this case the variable will not be initialized and you will see a warning in the task log
ExternalName=STRING|"Task1515"
ID=INTEGER|-77708332
Name=STRING|"Read section in the loop (JSON)"
StepPause=INTEGER|0
Name=STRING|"Set variable ""IniFile"" with value ""C:\temp\test.ini"""
_rt_variables_produced=STRING|"IniFile"
varname=STRING|"IniFile"
varvalue=STRING|"C:\temp\test.ini"
Name=STRING|"Set variable ""IniSection"" with value ""root"""
_rt_variables_produced=STRING|"IniSection"
varname=STRING|"IniSection"
varvalue=STRING|"root"
ActionID=STRING|"A_INI_LOOP"
Name=STRING|"INI Loop (by keys)"
_rt_variables_produced=STRING|"key,val"
filename=STRING|"{IniFile}"
keynamevar=STRING|"key"
keyvaluevar=STRING|"val"
loopmode=STRING|"1"
section=STRING|"{IniSection}"
message=STRING|"Key name = {key}; Value = {val}"
Name=STRING|"Set variable ""json:Collection.{key}"" with value ""{val}"""
_rt_variables_produced=STRING|"json:Collection.{key}"
varname=STRING|"json:Collection.{key}"
varvalue=STRING|"{val}"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"JSON collection completely:"
line00000001=STRING|"{Collection}"
line00000003=STRING|"*************"
line00000004=STRING|"How to read each value use {json:collection.<key_name>}"
line00000005=STRING|"Note that JSON is case sensitive"
line00000006=STRING|"for example"
line00000007=STRING|"{json:collection.Priority}"
line00000008=STRING|"{json:collection.ID}"
line00000009=STRING|"{json:collection.Name}"
linecount=STRING|"10"
timeout=STRING|"10"
ExternalName=STRING|"Task1516"
ID=INTEGER|2023322647
Name=STRING|"Read section in the loop (separate variables)"
StepPause=INTEGER|0
loopmode=STRING|"1"
Name=STRING|"Set variable ""{key}"" with value ""{val}"""
_rt_variables_produced=STRING|"{key}"
varname=STRING|"{key}"
fromfile=STRING|"1"
line00000000=STRING|"Priority = {Priority}"
line00000001=STRING|"id = {ID}"
line00000002=STRING|"Name = {Name}"
linecount=STRING|"3"
timeout=STRING|"10"
photoevents
- Contact:
Thanks, it's kind of obvious but I'm still learning.
Christian
Christian
