RoboTask 10.0 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 10.0 now
What's new in RoboTask 10.0:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
RoboTask 10.0
+ New action - "Label". The label for the GoTo action.
+ Changed GoTo action: it can jump to step by number or to Label
+ Added OAuth authorization for email actions. All email actions have been modified for this purpose.
+ New action Set Task Log Level. You can change the log level of a task
dynamically at runtime.
+ New variables: GMTOffset and GMTtoLocal
* HotKeys trigger: In the trigger editor you can see all the hotkeys used in other tasks.
* Modified CSV from dataset action: added timeout for SQL execution.
* Write text file: added "Without BOM" option.
* Modified email actions: added "Test connection" button.
* Modified actions: Search for Files, File loop and Synchronize Folders. Now you can set exclusion masks with folder names. That is, you can exclude certain
folders.
* Many other small optimizations, improvements and bug fixes.
Locked
