Round numbers or remove decimal places from variables
Mikaelo
Post by Mikaelo »
Please, how can I remove decimal places or round up/down variables?
Thanks, Michael
Re: Round numbers or remove decimal places from variables
You can use VB evaluate action (for example) with Round basic function
Also look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
CatID=INTEGER|327819672
ExternalName=STRING|"Task1476"
ID=INTEGER|-227308028
Name=STRING|"Round the value"
StepPause=INTEGER|0
Name=STRING|"Set variable ""pi"" with value ""3.14159"""
_rt_variables_produced=STRING|"pi"
varname=STRING|"pi"
varvalue=STRING|"3.14159"
Name=STRING|"VB Evaluate"
_rt_variables_produced=STRING|"IntegerValue"
expression=STRING|"round({pi},0)"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"IntegerValue"
Name=STRING|"Show ""pi = {pi}"""
msg0=STRING|"pi = {pi}"
msg1=STRING|"Rounded value = {IntegerValue}"
msgcount=STRING|"2"
