How to delete a file with the same name from files in multiple folders?
anthonyystwarty
Post by anthonyystwarty »
Hello, have a nice day!
I already looked and didn't find How to delete a file with the same name, ex test.mp3 which is on the local disk c:?
Can you help me?
Re: How to delete a file with the same name from files in multiple folders?
... delete a file with the same name, ex test.mp3 which is on the local disk ...
you can use File Loop to find files by name or mask in folder and sybfolders
Look at my example below. It seaches file list.txt in subfolders starting from folder D:\incoming\test\
ExternalName=STRING|"Task19"
ID=INTEGER|1222396254
Name=STRING|"Find copies in a folder and subfolders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""startfolder"" with value ""D:\incoming\test"""
_rt_variables_produced=STRING|"startfolder"
varname=STRING|"startfolder"
varvalue=STRING|"D:\incoming\test"
Name=STRING|"Set variable ""SearchFile"" with value ""list.txt"""
_rt_variables_produced=STRING|"SearchFile"
varname=STRING|"SearchFile"
varvalue=STRING|"list.txt"
Name=STRING|"Set variable ""firstFile"" with value ""true"""
_rt_variables_produced=STRING|"firstFile"
varname=STRING|"firstFile"
varvalue=STRING|"true"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"filename"
date1=STRING|"20231104"
date2=STRING|"20231104"
destvar=STRING|"filename"
DuringMinutes=STRING|"1"
file0=STRING|"{startfolder}\{SearchFile}"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"3"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
value1=STRING|"{firstFile}"
message=STRING|"first file (keep it) {filename} "
Name=STRING|"Set variable ""firstFile"" with value ""false"""
varvalue=STRING|"false"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"The copy (remove it) {filename} "
anthonyystwarty
Hello, sorry for the delay Oleg. With your task I managed to find the list.txt, but how do I delete the list.txt from the folders? Thank you friend
Look at the new task. The step #10 (Delete file) removes extra copies of the file
Name=STRING|"Find copies in a folder and subfolders (with delete files)"
StepPause=INTEGER|0
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{filename}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
sort=STRING|"1"
sortby=STRING|"3"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Else"
anthonyystwarty
To delete all list.txt in the folders, is this the command? I am unable.
If I understood correctly you want to keep one file and delete rest files with same file name (as you wrote at the beginning of the topic). Correct?
In this case you should delete files sequentially as in my task and keep 1-st file
If you write delete file by mask (list*.txt) - the action removes all files
If you want to delete all files by mask you don't need such complex algorithm, just use the action Delete file with Process subfolders option
The mask example: d:\incoming\list*.txt
In this case the action deletes all files list*.txt in folder d:\incoming and all subfolders
anthonyystwarty
Now I got it friend, you are kind and very intelligent. Thank you very much.
