RoboTask 9.7 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 9.7 now
What's new in RoboTask 9.7:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
RoboTask 9.7
+ New action "Log Dialog"
+ New trigger "Registry Monitor"
+ New action "SQL Query to CSV File"
+ Added a recycle bin for deleted tasks. When you delete a task, it is not deleted immediately.
* Modified "CSV Merge" action. Added "Merge Mode" option.
* The "CSV remove duplicates" action has been changed. Added "Remove Duplicates Mode". You can only check against the specified columns.
* Smart task sorting mode has been implemented in the main window.
* Many other small optimizations, improvements and bug fixes.
Locked
