Deleting Folders task
tlathum
Post by tlathum »
I need a little help creating a task to delete folders that are setup in date format YYYYMMDD that are older than 15yrs. I have to do it by the folder name because the Date Modified doesn't correlate with the folder name date. I just can't get the logic down and would appreciate any help from the community.
Re: Deleting Folders task
It's very good that you are using the universal date format YYYYMMDD
It makes everything easier
Use File loop action by folders and compare folder name with border date in the loop
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
Next you can see it in task editor
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1004"
ID=INTEGER|-6684713
Name=STRING|"Remove old folders (15 years)"
StepPause=INTEGER|0
ToLog=INTEGER|2
Name=STRING|"Set variable ""FolderName"" with value ""d:\testFolder"""
_rt_variables_produced=STRING|"FolderName"
varname=STRING|"FolderName"
varvalue=STRING|"d:\testFolder"
Name=STRING|"Set variable ""BorderDate"" with value ""{Subtract({Year},15)}{MonthNo}{Day}"""
_rt_variables_produced=STRING|"BorderDate"
varname=STRING|"BorderDate"
varvalue=STRING|"{Subtract({Year},15)}{MonthNo}{Day}"
message=STRING|"Border date is: {BorderDate}"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"CurrentFolder"
date1=STRING|"20230804"
date2=STRING|"20230804"
destvar=STRING|"CurrentFolder"
DuringMinutes=STRING|"1"
file0=STRING|"{FolderName}\*."
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
operator=STRING|"5"
value1=STRING|"{ExtractFileName({CurrentFolder})}"
value2=STRING|"{BorderDate}"
message=STRING|"Folder ""{CurrentFolder}"" This folder must be deleted"
type=STRING|"1"
message=STRING|"Put here ""Remove folder"" action"
type=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"Folder ""{CurrentFolder}"" skipped"
