Assign a keyboard shortcut to stop a macro?
anthonyystwarty
Post by anthonyystwarty »
Hello Oleg. Is there a way to assign a keyboard shortcut for example (ESC) to stop a macro in progress? And another question, is there a way to speed up the macro playback speed?
anthonyystwarty
Re: Assign a keyboard shortcut to stop a macro?
Hello, anyone to help? or does not have this function really in the robo?
To stop one task use "Stop" button on toolbar of main window. Select rrunning task and click on "Stop" button or use menu Task->Stop. Also this item is in popup menu.
If you want to stop all tasks the use the task Stop all tasks.tsk
You can find many useful examples here: https://robotask.com/samples/
anthonyystwarty
Oleg wrote: Thu Jul 06, 2023 3:20 pm To stop one task use "Stop" button on toolbar of main window. Select rrunning task and click on "Stop" button or use menu Task->Stop. Also this item is in popup menu.
Hello Oleg, thanks for the answer, I forgot to answer. He turned out perfect.
