Read a Textfile , Append, Save Textfile
gremlin
Post by gremlin »
Hy,
I had a problem.
Robotask can´t Read / Write a Textfile.
CatID=INTEGER|0
DoNotStopWhenShutdown=INTEGER|1
ExternalName=STRING|"Task4"
ID=INTEGER|736713264
LocalVariables=STRING|"DATEIUNDPFAD="
Name=STRING|"Sander EP"
Name=STRING|"Input Box"
password=STRING|"0"
prompt=STRING|"Länge"
stopifcancel=STRING|"0"
variable=STRING|"LAENGE"
password=STRING|"0"
prompt=STRING|"Breite"
variable=STRING|"BREITE"
password=STRING|"0"
prompt=STRING|"Höhe"
variable=STRING|"HOEHE"
ActionID=STRING|"A_READ_TXTFILE"
Name=STRING|"Read Text File ""{DATEIUNDPFAD}"" (1252)"
codepage=STRING|"1252"
filename=STRING|"{DATEIUNDPFAD}"
replacenull=STRING|"0"
varname=STRING|"CSV"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"CSV"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"CSV"
Name=STRING|"Set varible ""NEWFILENAME1"" with value ""C:\Temp\Dst\{ExtractFileNameNoExt({FileToProcess})}[{Year}-{MonthNo}-{Day}][{Hours}-{Minutes}-{Seconds}].{ExtractFileExt({FileToProcess})}"""
varname=STRING|"NEWFILENAME1"
varvalue=STRING|"c:\JTL-TMP\{Year}{MonthNo}{Day}{Time}{Seconds}.csv"
Name=STRING|"Create text file {NEWFILENAME1}"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{NEWFILENAME1}"
line0=STRING|"{CSV}{LAENGE};{BREITE};{HOEHE};;;;"
suppress=STRING|"0"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-263111290
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"C:\JTL-TMP"
foldercount=STRING|"1"
incmask=STRING|"Sander-EP.csv"
interval=STRING|"10"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlistparameter=STRING|"DATEIUNDPFAD"
notsavestatus=STRING|"0"
onelistparameter=STRING|"DATEIUNDPFAD"
pass=STRING|"1"
passmode=STRING|"1"
required=STRING|"0"
saveresults=STRING|"0"
subfolders1=STRING|"0"
Maybe anyone can help me.
Re: Read a Textfile , Append, Save Textfile
Could you send the file "Sander-EP.csv" for investigation to me to oleg(at)robotask.com
Probably your file contain some restricted symbols for code page 1252
Also try this task
CatID=INTEGER|693415217
ExternalName=STRING|"Task44"
ID=INTEGER|212909958
Name=STRING|"Sander EP (v2)"
password=STRING|"0"
password=STRING|"0"
password=STRING|"0"
prompt=STRING|"HГ¶he"
Name=STRING|"Set variable ""CSV"" with value ""{TextFile({DATEIUNDPFAD})}"""
varvalue=STRING|"{TextFile({DATEIUNDPFAD})}"
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"CSV"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
encode=STRING|"0"
suppress=STRING|"0"
UniqueID=INTEGER|2081193478
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
listmode=STRING|"1"
new=STRING|"1"
pass=STRING|"1"
passmode=STRING|"1"
required=STRING|"0"
gremlin
Post by gremlin »
Hy,
thank you.
I had tried but at the CSV file no variable output , only the name of the variable ...
Also I must change the filename time with a : won´t write a filename ...
I had send you file via email
Thanks
Steven
":" is restricted symbol in file name.
Also you can not use several other symbols: *,?,\,/,",'
gremlin
Post by gremlin »
Yes, I had solved this with the filename.
But at the outputfile there should be the variable {csv} string, not the name of the variable.
At the textfile 3 variables shows their value, but the {cvs} variable show only the text csv ???
Any idea ?
Thanks
Steven
Look at the step #5 (STR Trim)
you must use expression {csv} as source string (not CSV)
CSV is only CSV nothing more. But the expression {CSV} tells RoboTask that there is a variable name between braces and the task must try to extract the value.
gremlin
Post by gremlin »
Hy,
yes I had tried this.
But when I use {csv} the output are this:
120;80;111;;;;
The three results are the values from the inputboxes.
But the string{cvs} should be before the result from inputbxes. but theres nothing ?
The Result should be: Robotask wait for a csv file. When exists ask for 3 Values. Add these to the end of the csv File and rename/move csv file.
Please can you help me to understand.
look at my next version below. It works.
CatID=INTEGER|799397369
ExternalName=STRING|"Task25"
ID=INTEGER|976207299
Name=STRING|"Sander EP (v3)"
RunOnClose=INTEGER|1
password=STRING|"0"
password=STRING|"0"
password=STRING|"0"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{DATEIUNDPFAD}"
spaces=STRING|"0"
tabs=STRING|"0"
trailing=STRING|"1"
variable=STRING|"DATEIUNDPFAD"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{CSV}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Enabled=INTEGER|0
message=STRING|"{csv}"
Name=STRING|"Set variable ""NEWFILENAME1"" with value ""c:\JTL-TMP\{DateTimeToFormat({DateTime},yyyy-mm-dd-hh-nn-ss)}.csv"""
varvalue=STRING|"c:\JTL-TMP\{DateTimeToFormat({DateTime},yyyy-mm-dd-hh-nn-ss)}.csv"
encode=STRING|"0"
line0=STRING|"{CSV}"
line1=STRING|"{LAENGE};{BREITE};{HOEHE};;;;"
linecount=STRING|"2"
suppress=STRING|"1"
UniqueID=INTEGER|-529654911
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
listmode=STRING|"1"
new=STRING|"1"
pass=STRING|"1"
passmode=STRING|"1"
required=STRING|"0"
The main problem is :
When you try to pass the list of changed files to the task from trigger it is the list of files. One file name per line and each line ended with EOL (end-of-line) symbols. So TextFile variable can not find the file.
Generally it is the text and you must process it in the text loop.
But you configured the trigger to return only one filename. So you need to cut off the EOL characters from the filename variable. Look at step #4 of my example.
gremlin
Post by gremlin »
Yes, thank you.
Now I understand.
Thanks Steven
