How to play a sequence of videos with time between them?
anthonyystwarty
Post by anthonyystwarty »
Hello, another question, now with videos. I have 2 videos, one we'll call video(1), and the other video(2). I would like 10 seconds after closing the video(1), to start the video(2). The task I did did not work, because the video(1) is much longer than 10 seconds.
Would you help me?
Re: How to play a sequence of videos with time between them?
Probably you should run video payer with option "Wait until the application exits"
Of course you must use the command line which closes videoplayer when it finish playing
It seems the standard Windows Media Player does not stop application when the movie is ended...
For example, you can use the VLC media player (it's free and very powerful and flexible player).
The command line is:
vlc --play-and-exit MyMovie.mp4
anthonyystwarty
Oleg wrote: ↑Fri Jan 20, 2023 9:42 am Probably you should run video payer with option "Wait until the application exits"
Congratulations.
Unfortunately I couldn't. It says the following message:
VLC --PLAY-AND-EXIT VID1.MP4 (Invalid variable name) VID1.mp4, is the name of the video in the folder. That's right? Where am I going wrong?
You should use the full file name
for example
vlc --play-and-exit "C:\Users\username\AppData\Local\Packages\Microsoft.MicrosoftMinesweeper_8wekyb3d8bbwe\LocalState\vungleDiskCache\987eb941-9809-4e89-aeb6-6736a8d5fe48.mp4"
it works
Also please note that commands of VLC are case-sensitive
Look at my small example
CatID=INTEGER|693415217
ExternalName=STRING|"Task49"
ID=INTEGER|1470755940
Name=STRING|"Run movie in VLC"
Name=STRING|"Run ""vlc  --play-and-exit  ..."
ifnonzero=STRING|"0"
params=STRING|" --play-and-exit {EOL}""C:\Users\username\AppData\Local\Packages\Microsoft.MicrosoftMinesweeper_8wekyb3d8bbwe\LocalState\vungleDiskCache\987eb941-9809-4e89-aeb6-6736a8d5fe48.mp4"" "
program=STRING|"vlc"
runas=STRING|"0"
wait=STRING|"2"
anthonyystwarty
You Oleg are amazing! Your explanation and example worked perfectly. Thank you again.
