Pop up notification with modified file name in a directory?
anthonyystwarty
Post by anthonyystwarty »
Hello. I know robotask has "file monitor" function, the question is:
When I create or modify a file inside the folder, is there any command that shows the name of the file that was created or modified? and that a popup of this modification appears to me? I hope you understand my question. Thank you again.
Re: Pop up notification with modified file name in a directory?
You can save the list of changed files to text file: to one file or separate files. See Save to file tab
Also you can pass these lists to the task. See Save to task Variables tab
Next you can process these lists as you wish
anthonyystwarty
Hello. Thank you for the answer, but I couldn't get it to work as I would like, unfortunately. I tried to do something similar to what High Criteria's File Alert Monitor does.
Look at my small example (below)
You can send these lists to email or write to some log or database.
CatID=INTEGER|693415217
ExternalName=STRING|"Task38"
ID=INTEGER|1353709377
Name=STRING|"File alert"
Name=STRING|"Create local variable ""FileList"" with value ""{UniqueFileName({TempDir}\*.txt)}"""
varname=STRING|"FileList"
varvalue=STRING|"{UniqueFileName({TempDir}\*.txt)}"
Name=STRING|"Create text file {FileList}"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{FileList}"
line0=STRING|"Time: {DateTime}"
line2=STRING|"New files:"
line3=STRING|"{NewFiles}"
line5=STRING|"Deleted files:"
line6=STRING|"{DeletedFiles}"
line8=STRING|"Changed files:"
line9=STRING|"{ChangedFiles}"
linecount=STRING|"10"
suppress=STRING|"0"
Name=STRING|"Run ""{FileList} """
ifnonzero=STRING|"0"
program=STRING|"{FileList}"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Play sound"
msg1=STRING|"Hey, awake!"
msgcount=STRING|"2"
playsound=STRING|"1"
showmessage=STRING|"0"
wavefile=STRING|"C:\Program Files (x86)\Microsoft Office\Office14\Groove\Sounds\Places\ALARM.WAV"
Name=STRING|"File Monitor"
UniqueID=INTEGER|1465055032
chg=STRING|"1"
chga=STRING|"1"
chglistparameter=STRING|"changedfiles"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
dellistparameter=STRING|"deletedfiles"
folder1=STRING|"C:\temp"
foldercount=STRING|"1"
incmask=STRING|"*.*"
interval=STRING|"15"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlistparameter=STRING|"newfiles"
notsavestatus=STRING|"1"
pass=STRING|"1"
passmode=STRING|"2"
required=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"1"
anthonyystwarty
Oleg wrote: Thu Jan 12, 2023 10:25 am Look at my small example (below)
encode=STRING|"0"
suppress=STRING|"0"
runas=STRING|"0"
wait=STRING|"0"
msgcount=STRING|"2"
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
listmode=STRING|"1"
new=STRING|"1"
pass=STRING|"1"
passmode=STRING|"2"
required=STRING|"1"
Apologies for the delay in response. It worked perfectly as I wanted. You and Robotask are very smart. Thank you.
