How to use/copy python output.
DrinStony
Post by DrinStony »
I run a script that outputs a two digits number.
How do I use that number in my next actions?
Copy/paste? Or something else?
Tnx
Re: How to use/copy python output.
You do not need use python STDOUT
You should export necessary values to RoboTask variable
Look at my small example (see below). The script calculates something and export the value
Read here about RoboTask object for Python
ExternalName=STRING|"Task78"
ID=INTEGER|-1894364826
Name=STRING|"Export variable from python"
ActionID=STRING|"A_SCRIPT_PYTHONSCRIPT"
Name=STRING|"Python Script"
script_0=STRING|"from robotask import *"
script_1=STRING|"# calculate something"
script_10=STRING|"rt = RoboTask()"
script_11=STRING|"rt.set_user_var('MyVariable', str(c))"
script_2=STRING|"a = 23.5"
script_3=STRING|"b = 37.8"
script_5=STRING|"c = a + b"
script_6=STRING|"# output the result to StdOut"
script_7=STRING|"print(c)"
script_9=STRING|"# export the value to RoboTask variable"
script_count=STRING|"13"
script_type=STRING|"0"
search_paths_count=STRING|"0"
use_embedded=STRING|"1"
Name=STRING|"Show ""Show the value from python script"""
msg0=STRING|"Show the value from python script"
msg2=STRING|"The value is: {MyVariable}"
msgcount=STRING|"3"
