Using Active Window
dondada
Using Active Window
Post by dondada »
Is there a way to have Robotask recoginize that a program is already running and then pass command line parameters/commands to it. I don't want it to open a new occurance of an already running program? I tried the window commands but they weren't working. I'm really trying to run a batch program utilizing an already open instance of a program. Can Robotask do this?
Using Active Window
Check the existence of process via system variable {IsProcessExists()}.
Also you can use "Wait for process" action. The action pauses the task and waits until the selected process (processes) is finished. After the monitored process is finished, the task is resumed. If the specified process is not in the memory at the moment when the action is due, the task is not paused.
