Replace multiple occurrences of a character
sarnusch
Post by sarnusch »
Good morning,
I am using a dataset loop to get data from a SQL Database.
After that it is written into a text file.
This is an example extract:
110611,"671,4",4022927075332,89915377,,
110612,"1000,98",4022927075325,89915376,,
110613,1527,9000000067417,89915378,,
My goal is to create a csv file from the data. So I actually need ";" instead of ",".
Is there any way to get the data with a ";" from the database?
Otherwise how can I just change the "," that is not between quotation marks (STR REPLACE?)?
Thanks in advance for some input.
Kind regards,
Sebastian
Re: Replace multiple occurrences of a character
Look at my example below.
ExternalName=STRING|"Task1410"
ID=INTEGER|-498667185
Name=STRING|"Change CSV format"
Action14=FOLDER
Name=STRING|"Set variable ""txt"" with value ""110611,""671,4"",4022927075332,89915377,,{EOL}110612,""1000,98"",4022927075325,89915376,,{EOL}110613,1527,9000000067417,89915378,,"""
varname=STRING|"txt"
varvalue=STRING|"110611,""671,4"",4022927075332,89915377,,{EOL}110612,""1000,98"",4022927075325,89915376,,{EOL}110613,1527,9000000067417,89915378,,"
Name=STRING|"Set variable ""NewLine"" with value ""{NewLine}{item}"""
varname=STRING|"NewLine"
varvalue=STRING|"{NewLine}{item}"
Name=STRING|"Set variable ""NewText"" with value ""{NewText}{NewLine}{eol}"""
[Actions\Action12\Params]
varname=STRING|"NewText"
varvalue=STRING|"{NewText}{NewLine}{eol}"
[Actions\Action14]
Name=STRING|"Show Text"
[Actions\Action14\Params]
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"Old text:"
line00000001=STRING|"{txt}"
line00000003=STRING|"=================="
line00000004=STRING|"New text"
line00000005=STRING|"{NewText}"
linecount=STRING|"6"
timeout=STRING|"10"
Name=STRING|"Set variable ""NewText"" with value """""
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{txt}"
sourcetext=STRING|"1"
ActionID=STRING|"A_TXT_COOMATEXT"
Name=STRING|"Comma-separated string -> text"
kind=STRING|"0"
line00000000=STRING|"{line}"
lines=STRING|"1"
variable=STRING|"line"
Name=STRING|"Set variable ""NewLine"" with value """""
destvar=STRING|"ITEM"
line0=STRING|"{line}"
Name=STRING|"If Then  //newline is not empty"
operator=STRING|"8"
value1=STRING|"{NewLine}"
Name=STRING|"Set variable ""NewLine"" with value ""{NewLine};"""
varvalue=STRING|"{NewLine};"
But probably we need to add possibility to change CSV format. I wrote this into our ToDo list
sarnusch
Post by sarnusch »
Hello Oleg,
thanks for your reply and your help.
I tested it and it basically works fine.
But the commas at the end will disappear after processing. This is not good because the file will be imported with another program and the space between every semicolon is a field even if it is a space.
For example:
110611,"671,4",4022927075332,89915377,, becomes
110611;671,4;4022927075332;89915377
But it has to be:
110611;671,4;4022927075332;89915377;;
Is it possible to realize that?
Kind regards,
Sebastian
Probably it happened because 2 last elements are empty...
I changed the task (see below):
  • Add some nonempty string to the end. See step #4 I added $$$ to the end
  • after transformation remove this marker (see step #12)
As you can see, the algorithm is not very simple. Therefore, we decided to add a new action to RoboTask that allows you to change the CSV format from standard to custom and conversely in one step. It will be in next release.
ExternalName=STRING|"Task1432"
ID=INTEGER|878988155
Name=STRING|"Change CSV format (version 2)"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Set variable ""txt"" with value ""110611,""671,4"",4022927075332,89915377,,{EOL}110612,""1000,98"",4022927075325,89915376,,{EOL}110613,1527,9000000067417,89915378,,{EOL}110613,1527,9000000067417,899..."""
varvalue=STRING|"110611,""671,4"",4022927075332,89915377,,{EOL}110612,""1000,98"",4022927075325,89915376,,{EOL}110613,1527,9000000067417,89915378,,{EOL}110613,1527,9000000067417,89915378,,NonEmpyValue"
Name=STRING|"STR Replace // remove end marker"
mode=STRING|"2"
source=STRING|"{NewLine}"
substring=STRING|"$$$"
variable=STRING|"NewLine"
[Actions\Action13\Params]
[Actions\Action14]
[Actions\Action15]
[Actions\Action15\Params]
fromfile=STRING|"1"
timeout=STRING|"10"
Name=STRING|"Comma-separated string -> text //add some non-empty string to the end"
kind=STRING|"0"
line00000000=STRING|"{line}$$$"
lines=STRING|"1"
operator=STRING|"8"
sarnusch
Post by sarnusch »
Hello Oleg,
thank you, that works fine for me now.
It would be great to just convert to CSV format with one action.
CSV is still needed so many cases.
Kind regards,
Sebastian
