Tail a log file
renders
Tail a log file
Post by renders »
Hi all.. I need to pull the last 10 lines from a text log file to be sent within an email..
Suggestions?
Thanks
Re: Tail a log file
Look at my example
The task counts lines and extracts last 10 lines from text
Look at the step #4. It calculates the start line in VB script
ExternalName=STRING|"Task310"
ID=INTEGER|-589362537
Name=STRING|"Text tail (last 10 lines)"
Name=STRING|"Set variable ""FileName"" with value ""C:\temp\test.txt"""
varname=STRING|"FileName"
varvalue=STRING|"C:\temp\test.txt"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{Txt}"
timeout=STRING|"10"
title=STRING|"Text tail"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"1"
filename=STRING|"{FileName}"
linecount=STRING|"0"
variable=STRING|"LineCount"
message=STRING|"{LineCount}"
Name=STRING|"VB Evaluate"
expression=STRING|"GetStartLine({LineCount}, 10)"
line00000000=STRING|"function GetStartLine(cnt, delta)"
line00000001=STRING|"  start = cnt - delta + 1"
line00000002=STRING|"  if start < 1 then"
line00000003=STRING|"    start = 1"
line00000004=STRING|"  end if"
line00000005=STRING|"  GetStartLine = start"
line00000006=STRING|"end Function"
line00000008=STRING|"'logmessage(GetStartLine(10, 15))"
linecount=STRING|"9"
loadfromfile=STRING|"1"
variable=STRING|"StartLine"
message=STRING|"{StartLine}"
Name=STRING|"Set variable ""txt"" with value """""
varname=STRING|"txt"
Name=STRING|"Simple Loop"
begin=STRING|"{StartLine}"
end=STRING|"{LineCount}"
variable=STRING|"NUM"
external=STRING|"1"
linenum=STRING|"{num}"
variable=STRING|"Line"
Name=STRING|"Set variable ""txt"" with value ""{txt}{Line}{Eol}"""
varvalue=STRING|"{txt}{Line}{Eol}"
renders
Re: Tail a log file
Post by renders »
Thanks Oleg.. Worked very well for most time..
However, I have found that occasionally so many items are being written to the log around the same time that 10 lines back doesn't not capture the event that I need to display. I have increased the count to 20 but then too much info is being shown.
Can you suggest some way to filter the text so that it only shows the items around the most recent line that contains the word 'failed'
Here is a sample log.. The line in question is at 14:01:22. Ideally, the tail would be filtered for 'failed' and then display 5 lines before and after. OR, at least with the same time stamp as the error line.
Any help is much appreciated.
Best regards,
Rob
14:01:04 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:04 Directory Monitor: 1 files detected
14:01:04 Importing file: 'C:\AudioDownload\SHOGB1A.wav'
14:01:04 Import: Direct category & ID import for 'SHOGB1A'
14:01:04 Active set Thu Jun 23 00:00:00 2022
14:01:08 Import: Time adjust 'SHOGB1A' 17542ms now 17541ms
14:01:08 Import: CART timing info added to 'SHOGB1A'
14:01:08 Import Successful: File 'C:\AudioDownload\SHOGB1A.wav' imported as 'SHOGB1A'
14:01:12 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:12 Directory Monitor: 1 files detected
14:01:12 Importing file: 'C:\AudioDownload\SHOGB1B.wav'
14:01:12 Import: Direct category & ID import for 'SHOGB1B'
14:01:12 Active set Thu Jun 23 00:00:00 2022
14:01:15 Import: Time adjust 'SHOGB1B' 96536ms now 96535ms
14:01:15 Import: CART timing info added to 'SHOGB1B'
14:01:15 Import Successful: File 'C:\AudioDownload\SHOGB1B.wav' imported as 'SHOGB1B'
14:01:16 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:16 Directory Monitor: 1 files detected
14:01:16 Importing file: 'C:\AudioDownload\SHOGB1C.wav'
14:01:16 Import: Direct category & ID import for 'SHOGB1C'
14:01:16 Active set Thu Jun 23 00:00:00 2022
14:01:22 Import: CART timing info added to 'SHOGB1C'
14:01:22 Import Successful: File 'C:\AudioDownload\SHOGB1C.wav' imported as 'SHOGB1C'
14:01:22 Directory Monitor: Searching '\\nas-1\AudioBus\!_MTS_IMPORT\WINGHAM\'
14:01:22 Directory Monitor: 2 files detected
14:01:22 Importing file: '\\nas-1\AudioBus\!_MTS_IMPORT\WINGHAM\BLACKBURN DIGITAL-CEEK JUNE 24 PODCAST PROMO.wav'
14:01:22 Import: Invalid category PRO, import failed
14:01:22 Import failed: No default category for '\\nas-1\AudioBus\!_MTS_IMPORT\WINGHAM\BLACKBURN DIGITAL-CEEK JUNE 24 PODCAST PROMO.wav'
14:01:23 Importing file: '\\nas-1\AudioBus\!_MTS_IMPORT\WINGHAM\BLACKBURN DIGITAL-CEEK JUNE 24 PODCAST.wav'
14:01:23 Import: Direct category & ID import for 'COMCEEK'
14:01:23 Active set Fri Jun 24 00:00:00 2022
14:01:23 Expiry set Fri Jul 08 00:00:00 2022
14:01:28 Import: Time adjust 'COMCEEK' 30473ms now 30472ms
14:01:28 Import: CART timing info added to 'COMCEEK'
14:01:28 Import Successful: File '\\nas-1\AudioBus\!_MTS_IMPORT\WINGHAM\BLACKBURN DIGITAL-CEEK JUNE 24 PODCAST.wav' imported as 'COMCEEK'
14:01:28 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:28 Directory Monitor: 2 files detected
14:01:28 Importing file: 'C:\AudioDownload\SHOGB1D.wav'
14:01:28 Import: Direct category & ID import for 'SHOGB1D'
14:01:28 Active set Thu Jun 23 00:00:00 2022
14:01:30 Import: Time adjust 'SHOGB1D' 11246ms now 11245ms
14:01:30 Import: CART timing info added to 'SHOGB1D'
14:01:30 Import Successful: File 'C:\AudioDownload\SHOGB1D.wav' imported as 'SHOGB1D'
14:01:30 Importing file: 'C:\AudioDownload\SHOGB1E.wav'
14:01:30 Import: Direct category & ID import for 'SHOGB1E'
14:01:30 Active set Thu Jun 23 00:00:00 2022
14:01:34 Import: Time adjust 'SHOGB1E' 88543ms now 88542ms
14:01:34 Import: CART timing info added to 'SHOGB1E'
14:01:34 Import Successful: File 'C:\AudioDownload\SHOGB1E.wav' imported as 'SHOGB1E'
14:01:35 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:35 Directory Monitor: 1 files detected
14:01:35 Importing file: 'C:\AudioDownload\SHOGB1F.wav'
14:01:35 Import: Direct category & ID import for 'SHOGB1F'
14:01:35 Active set Thu Jun 23 00:00:00 2022
14:01:36 Import: Time adjust 'SHOGB1F' 22035ms now 22034ms
14:01:36 Import: CART timing info added to 'SHOGB1F'
14:01:36 Import Successful: File 'C:\AudioDownload\SHOGB1F.wav' imported as 'SHOGB1F'
14:01:39 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:39 Directory Monitor: 1 files detected
14:01:39 Importing file: 'C:\AudioDownload\SHOGB2A.wav'
14:01:39 Import: Direct category & ID import for 'SHOGB2A'
14:01:39 Active set Thu Jun 23 00:00:00 2022
14:01:42 Import: Time adjust 'SHOGB2A' 21303ms now 21302ms
14:01:42 Import: CART timing info added to 'SHOGB2A'
14:01:42 Import Successful: File 'C:\AudioDownload\SHOGB2A.wav' imported as 'SHOGB2A'
14:01:47 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:47 Directory Monitor: 1 files detected
14:01:47 Importing file: 'C:\AudioDownload\SHOGB2B.wav'
14:01:47 Import: Direct category & ID import for 'SHOGB2B'
14:01:47 Active set Thu Jun 23 00:00:00 2022
14:01:49 Import: Time adjust 'SHOGB2B' 79217ms now 79216ms
14:01:49 Import: CART timing info added to 'SHOGB2B'
14:01:49 Import Successful: File 'C:\AudioDownload\SHOGB2B.wav' imported as 'SHOGB2B'
14:01:51 Directory Monitor: Searching 'C:\AudioDownload\'
14:01:51 Directory Monitor: 1 files detected
14:01:51 Importing file: 'C:\AudioDownload\SHOGB2C.wav'
14:01:51 Import: Direct category & ID import for 'SHOGB2C'
14:01:51 Active set Thu Jun 23 00:00:00 2022
14:01:55 Import: CART timing info added to 'SHOGB2C'
Re: Tail a log file
Look at the example below
It extracts 10 lines near error ("failed")
ExternalName=STRING|"Task1462"
ID=INTEGER|-1290200321
Name=STRING|"Text tail (lines near error)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Name=STRING|"Increment variable ""LineNum"""
incement=STRING|"1"
vaiable=STRING|"LineNum"
Name=STRING|"If Then //if not found the exit"
[Actions\Action12\Params]
operator=STRING|"1"
value1=STRING|"{found}"
[Actions\Action13\Params]
message=STRING|"Error not found"
[Actions\Action14]
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
[Actions\Action15]
[Actions\Action16]
Name=STRING|"VB Evaluate //get start line"
[Actions\Action16\Params]
expression=STRING|"GetStartLine({LineNum}, 5)"
[Actions\Action17]
[Actions\Action17\Params]
[Actions\Action18]
[Actions\Action18\Params]
[Actions\Action19]
[Actions\Action19\Params]
end=STRING|"{Add({StartLine},9)}"
Name=STRING|"Set variable ""LineNum"" with value ""1"""
varname=STRING|"LineNum"
varvalue=STRING|"1"
[Actions\Action20]
[Actions\Action20\Params]
external=STRING|"1"
[Actions\Action21]
[Actions\Action21\Params]
[Actions\Action22]
[Actions\Action23]
[Actions\Action23\Params]
fromfile=STRING|"1"
timeout=STRING|"10"
Name=STRING|"Set variable ""found"" with value ""false"""
varname=STRING|"found"
varvalue=STRING|"false"
Name=STRING|"//Search error "
comment=STRING|"Search error "
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
file=STRING|"{fileName}"
sourcetext=STRING|"0"
operator=STRING|"6"
value1=STRING|"failed"
value2=STRING|"{line}"
Name=STRING|"Set variable ""found"" with value ""True"""
varvalue=STRING|"True"
Name=STRING|"Break"
renders
Re: Tail a log file
Post by renders »
Once again, THANK YOU!
