Looking for a simple example for networkcommand.exe
pkwong
Post by pkwong »
Hi. Here's to hoping someone can provide a simple command example:
I have a need to use the networkcommand.exe CLI (via dos) to set 2 local variables, then run a task.
Here are some known basics (for the purpose of the example):
Robotask Name: example-login
Variable1={USERNAME}
Variable2={PASSWORD}
ip of host listener: 192.168.1.10
port: 5500
Listener set up: (there are 3)
Listener 1:
Network->Listener
(Starts with) Wait for String = "APPUSER=" -----> "Save Received string as Local User Variable --> {USERNAME}"
Listener 2:
Network->Listener
(Starts with) Wait for String = "PASSWORD=" -----> "Save Received string as Local User Variable --> {PASSWORD}"
Listener 3:
Network->Listener
(Exact String): example-login ---> Everything else blank. This will be to start the task if it sees "example-login" as the string.
So.. on the machine I want to use networkcommand.exe on, I'm issuing the following command (from the dos prompt):
networkcommand.exe srv=192.168.1.10 cmd="APPUSER=myuser" port=5500
I get the following response:
Receive data: Timeout is over or unexpected connection closing
What I'm trying to achieve is:
1. Set Username
2. Set Password
3. Run the task
Where am I going wrong? Any help would be very much appreciated. The console of the "server" machine where the task will be run sees the connection coming in.
Re: Looking for a simple example for networkcommand.exe
1. The default port for Listener trigger is 5254. You can set your parameters in Network Plugin settings.
Just click on the button "Plugin settings" of trigger editor.
2-nd way:
  • open dialog Options | settings
  • Go to Plugins tab
  • find and select Network plugin
  • press Configure button
Default port 5500 is for client-server functions and has different protocol. So you got an error.
Listener launches the task and it can pass received value to the task as local variable
2. Look at my example below
Listener trigger starts the task and it reacts to the string "runtask" in the beginning of the command.
Listener port is 5254 without password
Next you can use NetWorkCommand.exe with this command line
NetWorkCommand.exe srv=localhost cmd="runtask,MyUserName,MyPassword" port=5254
The command as comma-separated string:
1-st element is the command
2-nd element the user name
3-nd element the password
ExternalName=STRING|"Task77"
ID=INTEGER|1328771684
Name=STRING|"Example for Listener"
Name=STRING|"Set variable ""usr"" with value ""{FullCommand(1)}"""
varname=STRING|"usr"
varvalue=STRING|"{FullCommand(1)}"
Name=STRING|"Set variable ""psw"" with value ""{FullCommand(2)}"""
varname=STRING|"psw"
varvalue=STRING|"{FullCommand(2)}"
Name=STRING|"Show ""Run something """
msg0=STRING|"Run something "
msg1=STRING|"received command {FullCommand}"
msg3=STRING|"username = {usr}"
msg4=STRING|"password = {psw}"
msgcount=STRING|"5"
EventID=STRING|"E_NET_LISTENER"
Name=STRING|"Listener"
UniqueID=INTEGER|961308698
assign=STRING|"0"
option=STRING|"1"
parameter=STRING|"FullCommand"
string=STRING|"runtask"
useparameter=STRING|"1"
pkwong
Post by pkwong »
Thank You so much! It was a very clear and concise example!
Cheers.
