Transfering Data Between Web Pages
starguy
Post by starguy »
I've taken a look at the "action" commands in RoboTask (I downloaded the software earlier today) but I don't readily see how I can program the following simple task:I plan to open two browser tabs in Firefox and have particular web sites open in each tab. I will manually copy data from the first site to the Windows clipboard. Then, using a "hotkey" command (programmed in RoboTask), I wish to open the second browser tab and have the clipboard contents transferred to a particular entry box in the open web site and then have the enter key exceuted.Is the above task programmable in RoboTask. If so, can you give me some simple pointers to get me going?
You can configure this task with using "Send keystrokes" and mouse actions. But you can encounter some difficulties, because forms are very differing on different sites.
