Import local variables into python / JS
DK.Ideagen
Post by DK.Ideagen »
How does one work with local variables in an internal python/js script.
In my own tests it leads to a syntax error.
One workaround was passing them as a prefix e.g.
rt.start_task("PREFIXVAR", "PREFIX="+str(row))
How would you do it?
Re: Import local variables into python / JS
start_task(ext_name, params = '')
Method.
Start task by number or External Name.
Parameters
  • ext_name - task number or external name
  • params - parameters of the task to be launched. Empty string by default. Parameters can be set as text, one parameter per line :
    parameter_name=parameter_value
External name is alternative ID of the task. You can set it in "Advanced" tab of task editor
Read more here about RoboTask object for python
