SFTP login error
ts67
SFTP login error
Post by ts67 »
I'm trying to login to a SFTP server and get the following error:
I 2022-03-03 13:09:29: ****** Starting task: *Faktura FaktFil tol FTP ******************
I 2022-03-03 13:09:29: Executing "1.SFTP Open (xxxx@sftp.yyyyy.com)"
E 2022-03-03 13:09:30: Can't open SFTP session
E 2022-03-03 13:09:30: | password
E 2022-03-03 13:09:30: | Enter password for xxxx
E 2022-03-03 13:09:30: | Password:
E 2022-03-03 13:09:30: An error occurred. Step #1 (SFTP Open (xxxx@sftp.yyyyy.com)).
E 2022-03-03 13:09:30: Task execution is aborted
When I try psftp.exe instead I have no problem to login.
What am I doing wrong?
Re: SFTP login error
What SFTP server do you use?
ts67
Post by ts67 »
Oleg wrote: ↑Tue Mar 08, 2022 4:58 pm What SFTP server do you use?
psftp.exe 0.73.0.0
The one that comes with the version of Robotask that we are using, I think.
PSFTP is sFTP client. RoboTask uses this utility in SSH FTP actions
What Server?
ts67
Post by ts67 »
Oleg wrote: ↑Wed Mar 16, 2022 1:49 pm PSFTP is sFTP client. RoboTask uses this utility in SSH FTP actions
What Server?
I don't understand the question?
We are running Robotask 7.8 by the way.
Could you send your task to me (oleg(at)robotask.com)?
Otherwise I can't help you
Select the task
Use menu Task->Export to export task to a file
send this file to me
