Passing Arguments with Excel Run Macro
twolsey
Post by twolsey »
Hello
Is there a way with Excel Run Macro action to pass arguments to the macro?
thanks
Tony
Re: Passing Arguments with Excel Run Macro
Excel application allows to run macro manually or by hot-key. But it does not allow to pass something to a macro.
We made the similar function.
However the object model of Excel application allows to pass up to 30 parameters to a macro.
Probably we need to improve this action
Kathrin_N
Post by Kathrin_N »
Would this solve my problem, too? I want to process Excel Sheets automatically. When I open an Excel Sheet without Robotask everything works fine and the data update automatically. When I open the Sheet with Robotask the background processes do not start. It is a Excel Sheet with Power Query.
Regards Kathrin
How to run macro with arguments
Suppose we have very simple macro in excel document
Sub MyMacro(Amsg)
    MsgBox Amsg
End Sub
To run the macro use such expression:
book1.xlsm!'MyMacro "Hello Wold!!!"'
or
Note that the entire macro expression must be enclosed in single quotes.
The macro function argument must be enclosed in double quotes.
Also look at simple example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
ExternalName=STRING|"Task1040"
ID=INTEGER|-618855983
Name=STRING|"EXCEL macro with arguments"
filename=STRING|"C:\temp\Book1.xlsm"
hide=STRING|"0"
mode=STRING|"0"
tryconnect=STRING|"1"
ActionID=STRING|"A_EXCEL_RUNMACRO"
Name=STRING|"Excel run macro ""book1.xlsm!'MyMacro ""Hello Wold!!!""'"""
macroname=STRING|"book1.xlsm!'MyMacro ""Hello Wold!!!""'"
To use some cell value as argument of macro use such expression
book1.xlsm!'MyMacro evaluate("C4")'
