Print PDF files automatically
mploug
Post by mploug »
We have RoboTask 6.7.2.911 running on a Windows server.
We want to create a task that continuously looks for PDF files in a specific folder.
We want the PDF files to be printed automatically to a specific printer.
When the PDF files have been printed we want them to be moved automatically
to another specific folder.
We have to use wildcard (*.pdf) because we don't know the file names.
I think we can use LibreOffice as PDF reader/PDF writer. Is that correct?
Foxit PDF Reader does not support wildcards.
Can we use the action Print Document for the task?
If so, how and where do we tell RoboTask that it should use LibreOffice as PDF reader/PDF writer?
Do we have to use the actions Run Program/Open Document, Print Document and Copy/Move File
in combination to create the task or how can we solve it?
Thank you in advance.
Kind regards,
Martin
Re: Print PDF files automatically
I answered similar question. See here: viewtopic.php?p=8664#p8664
You can enumerate files in the loop and print them sequentially file by file
look at my example (see below)
CatID=INTEGER|2091259954
ExternalName=STRING|"Task132"
ID=INTEGER|2142044237
Name=STRING|"Print PDF by mask"
Name=STRING|"Set variable ""folder"" with value ""c:\incoming"""
varname=STRING|"folder"
varvalue=STRING|"c:\incoming"
Name=STRING|"File Loop"
date1=STRING|"20211209"
date2=STRING|"20211209"
destvar=STRING|"PDFFILE"
DuringMinutes=STRING|"1"
file0=STRING|"{folder}\*.pdf"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Run ""foxitreader.exe /p ""{PDFFile}"""""
ifnonzero=STRING|"0"
params=STRING|"/p ""{PDFFile}"""
program=STRING|"foxitreader.exe"
runas=STRING|"0"
wait=STRING|"2"
