i want create variable for random text
elwaleed
Post by elwaleed »
i created variable
{MYVAR} = " John" , "Edi Forad " , " Donald Boka"
i want random for this text
i add {MYVAR(1 or 2 or 3)}
but not work its show first name every time
sorry for my bad english
Re: i want create variable for random text
Look at my example.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task50"
ID=INTEGER|-605196879
Name=STRING|"Random name"
ToLog=INTEGER|2
Name=STRING|"Set variable ""names"" with value """"John"" , ""Edi Forad "" , "" Donald Boka"", ""Marty"", ""James Bond"""""
varname=STRING|"names"
varvalue=STRING|"""John"" , ""Edi Forad "" , "" Donald Boka"", ""Marty"", ""James Bond"""
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"10"
Enabled=INTEGER|0
message=STRING|"{RandomValue(3)}"
Name=STRING|"Show ""Random name:"""
msg0=STRING|"Random name:"
msg2=STRING|"{names({RandomValue(5)})}"
msgcount=STRING|"3"
elwaleed
Post by elwaleed »
sorry if i ask you again
i can use variables with my task
but how can i use this task with my main task
Set variable MyVar with this value
"John" , "Edi Forad " , " Donald Boka", "Marty", "James Bond"
To get random name use the expression
{MyVar({RandomValue(N)})}
N - the number of elements in variable
In this case N=5
{MyVar({RandomValue(5)})}
