Can I create an automatic file sorting and ordering script?
Nuno
Post by Nuno »
before i ask my question I wish to thank you for your awesome software. I discovered it yesterday and I will use it forever, most probably lol.
I have a need to create a file sorting script. Of course, a download manager could have done it but since I now have a full-fledged suite I hope I can do something like so.
If file is zip, rar, 7z, tar.* then put it in \archives\ folder.
If file is mp3, wav, wma, etc then put the file in the media folder, and so on and so forth.
I would also want to group teh folder by years and month, so for example media\2021\10\myfile.mp3
Can it be done? I don't think I need specific instructions as I can figure it out on my own, but I just want to ask whether it is possible.
Thanks,
N.
Re: Can I create an automatic file sorting and ordering scri
Yes of course this is possible
I wrote an example how to do this.
The algorithm is not very simple but I hope you can figure it out.
CatID=INTEGER|1040932817
ExternalName=STRING|"Task1408"
ID=INTEGER|-673456280
Name=STRING|"Sort files by type and date"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Name=STRING|"Set variable ""source"" with value ""D:\testfolder\source"""
varname=STRING|"source"
varvalue=STRING|"D:\testfolder\source"
Enabled=INTEGER|0
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{txt}"
timeout=STRING|"10"
Name=STRING|"File Loop"
[Actions\Action12\Params]
date1=STRING|"20210925"
date2=STRING|"20210925"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"{txt}"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
timevar=STRING|"DT"
Name=STRING|"Set variable ""target"" with value ""{arcfld}\{DateTimeToFormat({dt},yyyy)}\{DateTimeToFormat({dt},mm)}"""
[Actions\Action13\Params]
varname=STRING|"target"
varvalue=STRING|"{arcfld}\{DateTimeToFormat({dt},yyyy)}\{DateTimeToFormat({dt},mm)}"
[Actions\Action14]
Enabled=INTEGER|0
[Actions\Action14\Params]
message=STRING|"{target}"
[Actions\Action15]
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
[Actions\Action15\Params]
destdir=STRING|"{target}"
f_count=STRING|"1"
file0=STRING|"{filename}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
[Actions\Action16]
[Actions\Action17]
Name=STRING|"//media"
[Actions\Action17\Params]
comment=STRING|"media"
[Actions\Action18]
Name=STRING|"Set variable ""txt"" with value """""
[Actions\Action18\Params]
varname=STRING|"txt"
[Actions\Action19]
Name=STRING|"Text Loop"
[Actions\Action19\Params]
destvar=STRING|"MASK"
line0=STRING|"{mediamask}"
sourcetext=STRING|"1"
Name=STRING|"Set variable ""arcFld"" with value ""D:\testfolder\archive"""
varname=STRING|"arcFld"
varvalue=STRING|"D:\testfolder\archive"
[Actions\Action20]
Name=STRING|"Set variable ""txt"" with value ""{txt}{source}\{mask}{EOL}"""
[Actions\Action20\Params]
varvalue=STRING|"{txt}{source}\{mask}{EOL}"
[Actions\Action21]
[Actions\Action22]
Enabled=INTEGER|0
[Actions\Action22\Params]
fromfile=STRING|"1"
timeout=STRING|"10"
[Actions\Action23]
[Actions\Action23\Params]
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
timevar=STRING|"DT"
[Actions\Action24]
Name=STRING|"Set variable ""target"" with value ""{mediafld}\{DateTimeToFormat({dt},yyyy)}\{DateTimeToFormat({dt},mm)}"""
[Actions\Action24\Params]
varvalue=STRING|"{mediafld}\{DateTimeToFormat({dt},yyyy)}\{DateTimeToFormat({dt},mm)}"
[Actions\Action25]
Enabled=INTEGER|0
[Actions\Action25\Params]
[Actions\Action26]
[Actions\Action26\Params]
f_count=STRING|"1"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
rename=STRING|"0"
subdir=STRING|"0"
system=STRING|"1"
[Actions\Action27]
Name=STRING|"Set variable ""mediaFld"" with value ""D:\testfolder\media"""
varname=STRING|"mediaFld"
varvalue=STRING|"D:\testfolder\media"
Name=STRING|"Set variable ""arcMask"" with value ""*.rar{EOL}*.zip{EOL}*.7z{EOL}*.tar"""
varname=STRING|"arcMask"
varvalue=STRING|"*.rar{EOL}*.zip{EOL}*.7z{EOL}*.tar"
Name=STRING|"Set variable ""mediaMask"" with value ""*.wav{EOL}*.jpg{EOL}*.wma{EOL}*.mp3"""
varname=STRING|"mediaMask"
varvalue=STRING|"*.wav{EOL}*.jpg{EOL}*.wma{EOL}*.mp3"
Name=STRING|"//archives"
comment=STRING|"archives"
line0=STRING|"{arcmask}"
