Print documents with specific software
mploug
Post by mploug »
Regarding the action Print Document:
I have watched the video on https://youtu.be/3USdgKhKbJc .
Can I use the parameters below if I want to tell RoboTask to use LibreOffice to print PDF files in a specific folder?
{libreoffice --writer}{C:\RoboTask\Test_ind\*.pdf}.
https://help.libreoffice.org/latest/he/ ... eters.html .
Thank you in advance.
Kind regards,
Martin
Re: Print documents with specific software
These parameters?
I'm afraid you won't succeed...
It seems if you want to print PDF you have to use --pt or -p parameters
Also to find all PDF files you have to use the File Loop (as in movie example)
