Print PDF files using wildcards
mploug
Post by mploug »
As far as I can see you can not use wildcards like *.* or *.pdf in command lines with Adobe Reader, Foxit PDF Reader or Sumatra PDF.
Correct me if I am wrong. Wildcards seem to work with LibreOffice.
I have tried to use the action Print Document with Foxit PDF Reader instead of command line.
It seems to work but is there any way I can ensure that RoboTask prints via Foxit PDF Reader everytime?
Thank you in advance.
Re: Print PDF files using wildcards
You can run Fixit Reader with command line to print PDF file
Look at Foxit Commands
But you have to enumerate all PDF files in the loop (see File Loop)
