Python parameters
andydoc1
Python parameters
Post by andydoc1 »
Sorry if I am being obtuse but this:
start_task(ext_name, params = '')
Method.
Start task by number or External Name.
Parameters
· ext_name - task number or external name
· params - parameters of the task to be launched. Empty string by default. Parameters can be set as text, one parameter per line :
parameter_name=parameter_value
is not at all clear
I have 3 parameters in the task 'ext_name' - how do i assign values from my script (where they are paramatised in a complex loop):
from robotask import *
from datetime import datetime, timedelta
def save_and_run_config():
    rt.start_task('test parameters 3', params = 'p1={symbol},p2={todate},p3={fromdate}')
for symbol in symbols:
    for x in (w + timedelta(n) for n in range(numdays+1)):
        weekendadj = 0
        if((x.weekday()==0) or (x.weekday()==6)):
            continue
        elif(x.weekday()==1):
            weekendadj = 2
        todate = x.strftime("%Y.%m.%d")
        y = x - timedelta(days=(2+weekendadj))
        #check market days
        fromdate = y.strftime("%Y.%m.%d")
I have tried various different alternatives - no joy!!
Re: Python parameters
In order to run the task with parameters use the expression
rt.start_task('TestParam', 'p1=Hello\np2=World\np3=Simple String')
This code starts the task with external name TestParam and pass 3 parameters: p1, p2, and p3
Look full examples below
1-st task which receives parameters. The tasks has external name TestParam
CatID=INTEGER|1163085779
ExternalName=STRING|"TestParam"
ID=INTEGER|1773267551
Name=STRING|"Show parameters"
Name=STRING|"Show ""param1 = {p1}"""
msg0=STRING|"param1 = {p1}"
msg1=STRING|"param2 = {p2}"
msg2=STRING|"param2 = {p3}"
msgcount=STRING|"3"
2-nd task. It launches 1-st task with 3 parameters in python script
ExternalName=STRING|"Task38"
ID=INTEGER|-1377614384
Name=STRING|"Python Script (run task with parameters)"
ActionID=STRING|"A_SCRIPT_PYTHONSCRIPT"
Name=STRING|"Python Script"
script_0=STRING|"from robotask import *"
script_1=STRING|"rt = RoboTask()"
script_2=STRING|"rt.start_task('TestParam', 'p1=Hello\np2=World\np3=Simple String')"
script_count=STRING|"3"
script_type=STRING|"0"
search_paths_count=STRING|"0"
use_embedded=STRING|"1"
Another way to pass some parameters: use dictionary
rt.start_task('TestParam', {"p1":"Hello","p2":"World","p3":"Simple String"})
It works too
