Managing Robotask service remotely
Prem
Post by Prem »
When using robotask NT service, the robotask icon is visible in the task pane of the local computer, but is invisible when using terminal services (remote desktop). That is very unpractical.
Is there a way to access the robotask nt service manager remotely?
thanks
RoboTask service can interact only with default desktop. Default desktop for terminal server is the local console of server. Any NT service can't interact with desktop in terminal session.
You can configure some autonomic tasks for RoboTask service. But you should use RoboTask as simple application for tasks, which requires interactive actions from you. RoboTask-service and RoboTask-application can work at a time without problems.
Now RoboTask service have no remote manager. We plan to add this feature in future.
