Active Window Fail Detection (RoboTask 8.2.3)
nehasaxena0284
Post by nehasaxena0284 »
I need help in detected an active window when the window machine is actually locked.
I have been able to successfully detect a window when the window is unlocked and I am logged in window but Window Active detection fails if I am logged off Window or have locked the window.
I am an administrator of Window machine and ROBOTASK is running as Administrator.
Please help me understand if it's a bug or it's feature behavior because my automation is unable to proceed due to failure detection of Active Window.
Thanks,
Neha Saxena
Re: Active Window Fail Detection (RoboTask 8.2.3)
When you lock the console the active window is Windows Default Lock Screen
I tested the simple example:
CatID=INTEGER|397884660
ExternalName=STRING|"Task1379"
ID=INTEGER|-1320335587
Name=STRING|"Log Message..."
ToLog=INTEGER|2
message=STRING|"{CurrentWindowHandle} {CurrentWindowCaption}"
Name=STRING|"Cyclic (every 2 sec)"
UniqueID=INTEGER|-60085393
interval=STRING|"2"
When I lock the session I get such result
-: 07.04.2021 15:34:59: 5308974 Windows Default Lock Screen
-: 07.04.2021 15:35:01: 5308974 Windows Default Lock Screen
-: 07.04.2021 15:35:02: 5308974 Windows Default Lock Screen
-: 07.04.2021 15:35:04: 5308974 Windows Default Lock Screen
-: 07.04.2021 15:35:06: 5308974 Windows Default Lock Screen
-: 07.04.2021 15:35:09: 5308974 Windows Default Lock Screen
