e-mail help
ccrespo
e-mail help
Post by ccrespo »
How would i program robotask to e-mail different people when files are added for different folders, but then delete those files when being sent.  But the files being moved into the folder are posted with a date time... for example INB120505.txt, is being moved into a "send" folder where it whould be e-mailed to someone then automatically be deleted...
The help that is provided online gives no insight into anything like this...and doesnt explain anything well..
e-mail help
See example below. This task will be launched every 60 sec and will send each *.txt file in folder "c:\source\to oleg" to me in separate messages. After sending the file will be removed.
If you have a few recipients you should have a few folders (one folder for each recipient)
Save text of the task into file and use menu Task | Import to import into RoboTask. Do not forget to enable this task after importing.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task354"
ID=INTEGER|1079978417
Name=STRING|"sending email automatically"
Name=STRING|"File Loop"
date1=STRING|"20051208"
date2=STRING|"20051208"
destvar=STRING|"FILE_TOSEND_OLEG"
file0=STRING|"C:\source\To Oleg\*.txt"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
from=STRING|"oleg@robotask.com"
host=STRING|"localhost"
html=STRING|"0"
msg0=STRING|"{TextFile({FILE_TOSEND_OLEG})}"
password=STRING|"2488926989246882673624690"
port=STRING|"25"
subject=STRING|"New incoming"
to=STRING|"oleg@robotask.com"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{FILE_TOSEND_OLEG}"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
id=STRING|"1HAUVA09"
interval=STRING|"60"
ccrespo
e-mail help
Post by ccrespo »
how do you learn to program like that, are there any additional resource materials i can invest in?
ccrespo
e-mail help
Post by ccrespo »
also whats the seperator for multiple e-mails? a semicolon ;?
e-mail help
You can use multiple emails like this:
user1@domain.com; user2@domain.com
or
"John Smith"<john@yahoo.com>; "Melissa Wetton"<mw@aol.com>
ccrespo
e-mail help
Post by ccrespo »
Also what about if the file is not a .txt file, if its a pdf or other type of file...?
e-mail help
You asked about text files.
Any other files you can mail as attachments
ccrespo
e-mail help
Post by ccrespo »
Also, I am having problems with sending multiple attachments......sorry for being such a pain, but i run the IT department of a logistics corporation and im just determining if robotask is worth investing in.
e-mail help
What a problem? Describe in more detail, please.
Or, better, send me your task. Probably you do something wrong.
ccrespo
e-mail help
Post by ccrespo »
;* Do not edit!       *
CatID=INTEGER|2091259954
Name=STRING|"Auto Mail"
destvar=STRING|"FILE_TOSEND"
file0=STRING|"C:\testsend\*.*"
subdirs=STRING|"1"
timesize=STRING|"0"
attach0=STRING|"{FILE_TOSEND}"
attachcount=STRING|"1"
auth=STRING|"0"
from=STRING|"EDI.Notifications@3plg.com"
html=STRING|"0"
msg0=STRING|"New Incoming PO"
password=STRING|"2591325450254552673618538"
port=STRING|"25"
subject=STRING|"NEW INCOMING PO"
to=STRING|"carlo.crespo@3plg.com"
Count=STRING|"1"
file0=STRING|"{FILE_TOSEND}"
subdir=STRING|"0"
id=STRING|"FTRLAWPB"
When executing, if there are multiple files in the folder, only one file is sent as an attachment.  I need it so that all of the files are included the e-mail
