Copy Variable to Variable
Nickel Plate
Post by Nickel Plate »
Is there anyway i can copy contents of one variable to another variable.
I copy software from internet each night which as a number as part of file name, have got two variables "OLDNUMBER" and "NEWNUMBER", so i would like to copy new into old at the end of the download so i do not have to look up old number each night
It is "Set Variable" action.
You should use the following parameters:
Variable Name - OLDNUMBER
Variable Value - {NEWNUMBER}
Expand Variable Value - ON // It is required
When you turn on "Expand Variable Value" parameter, RoboTask expands value before assigning. Otherwise value will be assigned "as is".
