Program Specific Hot Keys
Active
Post by Active »
Hello. I am quite new to robotask and I find it very
accurate.
In order to save me same time can you please advise how a
single key can send different keystrokes according to active window/program.
 For example I want the ` key to send keystrokes ^({F4}) (CTRL+F4)
when the active window is Mozilla Firefox and the same ` key to send keystrokes
%({F4}) (ALt+F4) when the active window is Internet Explorer.
See task below. Don't forget to enable the task after importing.
By the way: what do Ctrl-F4 key in Mozilla? I think that you want to close window of browser. Therefore Alt-F4 is valid for Mozilla too.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|2013454187
ExternalName=STRING|"Task172"
ID=INTEGER|1396778969
Name=STRING|"IE or Mozilla"
ActionID=STRING|"A_WINDOW_CHECK"
Name=STRING|"Check for Window"
abortif=STRING|"0"
action=STRING|"1"
checkfor=STRING|"1"
exact=STRING|"0"
variable=STRING|"IE_ACTIVE"
wincaption=STRING|"- Microsoft Internet Explorer"
abortif=STRING|"0"
action=STRING|"1"
checkfor=STRING|"1"
exact=STRING|"0"
variable=STRING|"mozilla_ACTIVE"
wincaption=STRING|"- Mozilla Firefox"
value1=STRING|"{ie_active}"
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"%({F4})"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
value1=STRING|"{mozilla_active}"
keys=STRING|"^({F4})"
sendkind=STRING|"0"
hotkey=STRING|"192"
Active
Post by Active »
Oleg wrote:By the way: what do Ctrl-F4 key in Mozilla? I think
Mozilla too.
Thanks a lot for your reply.
The CTRL+F4 is closing the present tab in Firefox and I just
want to assign different uses of the certain key.
The script you appended is working as wished.
Is there a form to work on it if I want to repeat this
process with other programs/hotkeys?
I mean, for example, use F2 to send keystrokes with my name when
MS Word is active, but when my antivirus is active I want to use F2 to update
it.
Can I use a form, in order same hotkeys have different
actions depending of the active window?
Thanks
You can write another task like this example, and use hot key F2 in triggering event. But remember that RoboTask intercept a hot key, and application don't receive this key combination. I think that better to do so:
if MsWord is active then
   send My Name
else
   if Antivirus is active then
      send Key combination to update
   else
      send F2 // sending Hot Key if another application
   end if
end if
