Email alert on new file in folder
renders
Post by renders »
Hi all.. I would like to monitor a network folder for new files and send an email alert only when a new file is detected..
Any suggestions on how to do this?
Thank you for any assistance..
Re: Email alert on new file in folder
Use File monitor trigger for the task
It can monitor mapped folders (for example z:\Reports\reports2020)
also you can use UNC names (for example \\Server1\SharedFolder\Reports\reports2020)
renders
Post by renders »
Thanks Oleg.. Here is what I cam up with.. Works fine..
CatID=INTEGER|0
ContinueOnError=INTEGER|2
ExternalName=STRING|"Task5"
ID=INTEGER|-469501598
Name=STRING|"MonitorAudioImport Fail"
OnErrorTaskID=INTEGER|618766971
operator=STRING|"8"
value1=STRING|"{files_n}"
message=STRING|"{files_n} Transfer failed"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"1"
cc=STRING|"??@??.com"
charset=STRING|"iso-8859-1"
from=STRING|"AudioImportMonitor@??.com"
host=STRING|"mail.com"
html=STRING|"0"
msg0=STRING|"{ExtractFileNameNoExt({files_n})} failed to import.."
msg2=STRING|" Please try it again."
msgcount=STRING|"3"
password=STRING|"fakepassword"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
subject=STRING|"{ExtractFileNameNoExt({files_n})} Failed to Import"
to=STRING|"??@??.com"
user=STRING|"??@??.com"
xmailer=STRING|"RoboTask"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-93055329
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"O:\AudioImport\Moved_files"
foldercount=STRING|"1"
incmask=STRING|"*.wav"
interval=STRING|"5"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlistparameter=STRING|"files_n"
pass=STRING|"1"
passmode=STRING|"2"
required=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
