Merging tasks
Prem
Merging tasks
Post by Prem »
Is there a way to merge tasks without having to eport them both and manually make a new text/taskfile of it?
Merging tasks
You should do it manually now. But you suggest a good feature again
Prem
Merging tasks
Post by Prem »
By the way, I tried to merge two tasks, by eporting both, copying one contents into the other (just one above the other), importing the merged file into robotask, but that does not work; only one task is recognised by robotask. the other just does not appear. What is your method for manually merging tasks?
