Array of integer
RaulAlonso
Array of integer
Post by RaulAlonso »
Hi
Can somebody help me please
I am trying to create an array of integers and then use the increment
function for each one of the array cells with loop, each time i am getting
an error "not valid integer value" or "Illegal name of variable"
Thank you
Re: Array of integer
RoboTask doesn't support arrays.
But you can use indexed variables. For example MyVar1, MyVar2, ...., MyVarN
Look at the small example below how to set values to the indexed variables in the loop and increment values in the loop
CatID=INTEGER|448832495
ExternalName=STRING|"Task221"
ID=INTEGER|-334982463
Name=STRING|"indexed variables (increment)"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"10"
variable=STRING|"NUM"
Name=STRING|"Set variable ""MYVAR{NUM}"" with value ""{num}"""
varname=STRING|"MYVAR{NUM}"
varvalue=STRING|"{num}"
Name=STRING|"Show ""Initial values"""
msg0=STRING|"Initial values"
msg1=STRING|"MyVar1 = {MyVar1}"
msg10=STRING|"MyVar10 = {MyVar10}"
msg2=STRING|"MyVar2 = {MyVar2}"
msg3=STRING|"MyVar3 = {MyVar3}"
msg4=STRING|"MyVar4 = {MyVar4}"
msg5=STRING|"MyVar5 = {MyVar5}"
msg6=STRING|"MyVar6 = {MyVar6}"
msg7=STRING|"MyVar7 = {MyVar7}"
msg8=STRING|"MyVar8 = {MyVar8}"
msg9=STRING|"MyVar9 = {MyVar9}"
msgcount=STRING|"11"
Name=STRING|"//Now we increment all variables by 1"
comment=STRING|"Now we increment all variables by 1"
begin=STRING|"1"
end=STRING|"10"
Name=STRING|"Increment variable ""MyVar{num}"""
incement=STRING|"1"
vaiable=STRING|"MyVar{num}"
Name=STRING|"Show ""After incremental"""
msg0=STRING|"After incremental"
