Inputting multiple variables at once?
DanMcKinney
Post by DanMcKinney »
Is there a way to input more than one variable at once? I've got over a dozen different variables to enter into a routine, and a multi-input box would be preferable to writing lines for a dozen inputs.
Re: Inputting multiple variables at once?
If you want input manually then only one variable at a time.
But you can make text file. For example you can put one value per line in Notepad™
The task can read it and put values into variables in the loop.
DanMcKinney
Thanks, Oleg!
