Erroneous Task
anonymouse
Erroneous Task
Post by anonymouse »
I evaluating the trial and a task keeps reappearing called Device changed, how do I remove it. Also are all the files necessary to run it on XP in the installation folder and what does the SD.exe do?
Erroneous Task
It is a task named "Device changed". You can disable this task or delete it at all. By default it is in folder "Root\Examples\simple". If you can't find the task, do following:
   - Hide task tree
   - You can sort full task list by name or by status. This task must have name "Device changed" and status "Idle (On Device Changed)"
SD.EXE is necessary for correct working of "Log Off" action
