Add characters to existing filename
Prem
Post by Prem »
I dont know how to rename a file by adding characters to the existing filename, for example "FAX-" in front of it. When I make the renaming action FAX-*.* (or FAX?.* works the same), the first four characters of the falename are replaced with FAX-, instead of adding the FAX- in front of the filename.
Any suggestions? Thanks
Try the example below. This task add prefix FAX- to all files in folder c:\temp, and next moves files with mask FAX-*.* to c:\incoming folder.
Save the text of task to file and use menu Task|Import to import into RoboTask.
By the way: you can find more examples here
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task310"
ID=INTEGER|163933500
Name=STRING|"Add Prefix to Filename"
Name=STRING|"File Loop"
date1=STRING|"20051001"
date2=STRING|"20051001"
destvar=STRING|"TEMP_FILE_NAME"
file0=STRING|"C:\Temp\*.*"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Rename File"
file0=STRING|"{temp_file_name}"
mask=STRING|"FAX-{ExtractFileName({temp_file_name})}"
subdirs=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"c:\incoming"
f_count=STRING|"1"
file0=STRING|"C:\Temp\fax-*.*"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
Prem
Post by Prem »
Thank you very much, Oleg
