Delete files older than a month
david
Post by david »
I'm trying to set up the delete action to remove a certain file types
from a folder that are older than a month, and for it to run once a
week. The scheduling is working fine, but i'm having difficulty adding
the command /variable for the delete action to act on that criteria. i
am new to this program and would appreciate some assistance.
You may delete old files by using File Loop action. Adjust date filter so that the cycle select files older than 1 month. See example below.
Save text of task to file and use menu Task | Import to import into RoboTask.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task302"
ID=INTEGER|338083437
Name=STRING|"Delete old files (older than 1 month)"
Name=STRING|"File Loop"
createmode=STRING|"4"
createormodified=STRING|"1"
date1=STRING|"20050921"
date2=STRING|"20050921"
destvar=STRING|"FILE_TO_DELETE"
file0=STRING|"C:\temp\*.*"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"Remove file {File_To_Delete}"
type=STRING|"1"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{File_To_Delete}"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Remove variable ""FILE_TO_DELETE"""
varname=STRING|"FILE_TO_DELETE"
