Counter
tommyhale@gmail.com
Counter
Post by tommyhale@gmail.com »
I need a task that will count elapsed days from a given date.
Re: Counter
Look at this example (see below)
CatID=INTEGER|1360203151
ExternalName=STRING|"Task160"
ID=INTEGER|-285266320
Name=STRING|"days left"
Name=STRING|"Set variable ""MYDATE"" with value ""{FormatToDateTime(20191101,yyyymmdd)}"""
varname=STRING|"MYDATE"
varvalue=STRING|"{FormatToDateTime(20191101,yyyymmdd)}"
ActionID=STRING|"A_TIMEDIFFERENCE"
Name=STRING|"Time Difference"
datetime1=STRING|"{date}"
datetime2=STRING|"{MyDate}"
format=STRING|"3"
valuekind=STRING|"0"
varname=STRING|"delta"
Name=STRING|"Show ""{delta} days left to {MyDate}"""
msg0=STRING|"{delta} days left to {MyDate}"
Re: Counter
Or this example
ExternalName=STRING|"Task190"
ID=INTEGER|-875444606
Name=STRING|"elapsed days"
Name=STRING|"Set variable ""MYDATE"" with value ""{FormatToDateTime(20190801,yyyymmdd)}"""
varvalue=STRING|"{FormatToDateTime(20190801,yyyymmdd)}"
datetime1=STRING|"{MyDate}"
datetime2=STRING|"{date}"
format=STRING|"3"
Name=STRING|"Show ""{delta} days elapsed from {MyDate}"""
msg0=STRING|"{delta} days elapsed from {MyDate}"
Dragon Slayer
Re: Counter
Post by Dragon Slayer »
And how do you count days from the current date to a certain date in the future?
Re: Counter
Look at 1-st example above
