How to use local variable in VB Evaluate expression?
DanMcKinney
Post by DanMcKinney »
I am trying to use VB Evaluate to calculate a simple expression that uses one of my local variables, called SF. I'm assigning the result to another local variable.
The equation is 0.02 * SF, but obviously SF doesn't work in the VB Evaluate expression box! How do I get my local variable into that expression? Is that accomplished through script?
I'll admit I know nothing about scripting. If someone could show my how this might work, I'd be grateful!
Re: How to use local variable in VB Evaluate expression?
You must use {SF} string in your expression
The expression is: 0.02*{sf}
RoboTask replaces the string {SF} with the value of the variable SF
look at my example please
CatID=INTEGER|1360203151
ExternalName=STRING|"Task154"
ID=INTEGER|116953570
Name=STRING|"VB Evaluate"
Name=STRING|"Set variable ""SF"" with value ""2500"""
varname=STRING|"SF"
varvalue=STRING|"2500"
expression=STRING|"0.02*{sf}"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"NewSF"
Name=STRING|"Show ""Old value = {SF}"""
msg0=STRING|"Old value = {SF}"
msg1=STRING|"New Value = {NewSF}"
msgcount=STRING|"2"
DanMcKinney
Oleg - Much appreciated! I love the product, by the way. I'm on the evaluation version now, but will definitely be purchasing the full version. Thanks again!
