Re: Do-While Loop
MatCh
Re: Do-While Loop
Post by MatCh »
I need to do something like this:
Wait for WindowActive"t1.doc - Microsoft Word"
Abort Task TimeOut = 20sec
Something like that.
I can't figure out which loop or action can do that, or is there a work around for it?
I think it could have been something like:
Do
delay = 500msec
while WinActive"t1.doc - Microsoft Word" = False
Re: Do-While Loop
Try the example below. This task waits for activation of window "Notepad" during 20s (100 loops by 0.2s) and informs you if the window will be activated. If the window remains inactive you get a message "Window Notepad still not active"
We are planning to add such actions as "Wait for window", "wait for file".
Regarding to "While ... loop" and "Loop ... until" actions. It's a good idea. I wrote this into our ToDo list.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task298"
ID=INTEGER|500632595
Name=STRING|"Wait for window active"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"100"
variable=STRING|"W_CNT"
Name=STRING|"Show ""Window ""Notepad"" still not active"""
icon=STRING|"0"
msg0=STRING|"Window ""Notepad"" still not active"
value1=STRING|"{IsWindowActive(Notepad)}"
Name=STRING|"Break"
Name=STRING|"Delay 200 ms"
delay=STRING|"2"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{w_cnt}"
value2=STRING|"100"
Name=STRING|"Show ""Window ""Notepad"" is active"""
msg0=STRING|"Window ""Notepad"" is active"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
