Automatic New IMAP emails sent and Archive
aa1508
Post by aa1508 »
Hello, I've been using Robotask for the past 6 months and thus far it phenomenal.
Would you help with the following task?
We need to send "Faxes" through email automatically.
Our current software generates two different files per each fax. .PDF and .FMI (opens with notepad)
6F24C248-1C8E-42DA-89C1-EE2FC47B8741.pdf
6F24C248-1C8E-42DA-89C1-EE2FC47B8741.fmi
The .fmi file content looks like the following:
[Fax]
UniqueId=6F24C248-1C8E-42DA-89C1-EE2FC47B8741
FileType=PDF
[From]
UserID=4
UserCompany=Your Company
UserName=Your username
[To]
FaxCompany=
FaxName=
FaxNumber=8881234567
FaxComments=
DialAreaCode=N
UseAreaCodeRules=N
[ClientRecord]
RecordID=E080C776-1B45-4CBC-9F9C-F9AB5F73AD81
RecordType=Document
I need to do the following:
1. Robotask periodically reviewing a folder for new files.
2. Sending an email with the .pdf file as an attachment
3. Extract the FAXNUMBER only from the .fmi file
4. Send an email to {FAXNUMBER}@faxingcompany.com (where @faxingcompany.com is always a constant)
5. Archive the original files to a different folder
I hope you can help. Thank you
Re: Automatic New IMAP emails sent and Archive
Look at my example please
CatID=INTEGER|1075658632
ExternalName=STRING|"Task611"
ID=INTEGER|27282500
Name=STRING|"FAX num"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Name=STRING|"Set variable ""INFOLDER"" with value ""D:\incoming\pdf"""
=STRING|""
varname=STRING|"INFOLDER"
varvalue=STRING|"D:\incoming\pdf"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{ArcFolder}"
f_count=STRING|"2"
file0=STRING|"{file}"
file1=STRING|"{pdf}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Fax number not found"""
[Actions\Action12\Params]
=STRING|""
icon=STRING|"3"
msg0=STRING|"Fax number not found"
[Actions\Action14]
Name=STRING|"Else"
[Actions\Action15]
Name=STRING|"Show ""File {PDF} is not found"""
[Actions\Action15\Params]
icon=STRING|"3"
msg0=STRING|"File {PDF} is not found"
[Actions\Action16]
[Actions\Action17]
Name=STRING|"Set variable ""ARCFOLDER"" with value ""D:\incoming\pdf-arc"""
varname=STRING|"ARCFOLDER"
varvalue=STRING|"D:\incoming\pdf-arc"
Name=STRING|"File Loop"
date1=STRING|"20190730"
date2=STRING|"20190730"
destvar=STRING|"FILE"
DuringMinutes=STRING|"1"
file0=STRING|"{InFolder}\*.fmi"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Set variable ""PDF"" with value ""{ExtractFilePath({file})}\{ExtractFileNameNoExt({File})}.pdf"""
varname=STRING|"PDF"
varvalue=STRING|"{ExtractFilePath({file})}\{ExtractFileNameNoExt({File})}.pdf"
value1=STRING|"{FileExists({PDF})}"
Name=STRING|"RegExp Match"
=STRING|""
anchored=STRING|"0"
extended=STRING|"0"
file=STRING|"{file}"
linecount=STRING|"0"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?im)^faxnumber=(\d+)$"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"1"
variable=STRING|"found"
=STRING|""
value1=STRING|"{found}"
Name=STRING|"Show ""fmi file: {file}"""
=STRING|""
msg0=STRING|"fmi file: {file}"
msg1=STRING|"PDF: {pdf}"
msg2=STRING|"FAX: {expr(1)}"
msgcount=STRING|"3"
Name=STRING|"//moving to archieve"
comment=STRING|"moving to archieve"
I think you are able to modify this example for your purposes
