RoboTask 7.3 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 7.3 now
What's new in RoboTask 7.3:
Legend
[+] Feature added
[-] Bug fixed
[*] Modified or improved[/i]
+ New action "STR Length"
+ New action "Excel Run Macro"
+ New system variables: FileCreateTime, FileLastAccessTime
+ New action "SSL FTP Check file"
+ New action "SFTP Check file"
+ Task Editor: added "Show Global Varables" function from task editor directly.
+ Added filter of global variables into Variables dialog
+ Added export/import global variables for remote RoboTask
* Changed "POP3 Open" action. Added SSL/TLS flags
* Changed "IMAP Open" action. Added SSL/TLS flags
* "Get File Metadata" action editor. You can see all non-empty properties for
specified file.
* Many other optimizations, improvements and bug fixes.
Locked
